3-Newcomer
April 20, 2015
Title Block Font Problem
  • April 20, 2015
  • 2 replies
  • 1824 views
In Wildfire 5.0, I have created a drawing Format and applied it to a lot of drawings, but on a few of them the fonts in the title block get hosed up when I export it to PDF. Somehow, the fonts are 3 times as large as they should be. For the life of me, I can't determine what is causing this to happen. There must be something in the model that is causing the issue because even if I recreate the drawing, the problem persists.
If I change the format to an older one, the problem goes away. This particular format has a table with parameter codes like &description in it. If I make a note on the drawing and export it to PDF, the parameter code is generated fine. But, the parameter codes in the title block table are 3 times too large.
Has anyone ever seen this issue? How do I resolve the issue?
Best answer by DonSenchuk
Do you check the box for 'Stroke all Fonts' when exporting to PDF? Sometimes not using that option causes problems with certain things.
(IIRC there is also a config or .dtl setting that will make this selection permanent.)
cenglish3-NewcomerAuthor
3-Newcomer
April 20, 2015
Don,
That worked, I owe you a beer!
