tolerances in drawing
  • February 19, 2015
  • 9 replies
  • 3876 views
in drawing there are many ways for displaying tolerances in drawing , i want to display tolerances to be like tol1.jpg not like tol2.jpg or tol3.jpg
all pic were attached
Best answer by Mahesh_Sharma
Yes, it is an old drawing option available in Creo 2.0 as well. Make sure your are checking this in drawing options not in config options (File > Prepare > Drawing Properties > Detail options > Change)
StephenW
Just curious as to why you didn't just attach the jpeg images directly instead of putting them in a .rar file. I generally don't open .rar files unless I am absolutely certain I know the contents.
deia_20081-VisitorAuthor
when i tried to put the image directly the massage ( this image type is forbidden ) why i do not know
Compressed file formats are blocked by corporate firewalls. I can not open .zip or .rar files.
i tried all the images extensions but no new
Mahesh_Sharma
22-Sapphire I
February 19, 2015
All,
tol1.jpg from Demac was as:
I don't think directly you can get this, however as an alternate option you can try using Plus-Minus tolerance mode and set lower tolerance to 0.0. After that blank 0.0 (lower tolerance) using drawing option blank_zero_tolerance as yes.
Result will be as:
thanks for reply but i did not find blank_zero_tolerance in drawing options ( i'm using creo 2)
StephenW
I'm in Creo 2 also. It's there under the tolerances section in the drawing setup. (not config.pro)
FILE, PREPARE, DRAWING PROPERTIES, change (across from detail options)
