transparent view, chamfer
  • June 3, 2015
  • 5 replies
  • 2314 views
how to get the transparent view in part?
Difference between Distance*D Offset*O.. In a diagram can anyone explain?
Best answer by dschenken
You are trying to set a transparent material - this is done with the appearances tab under Render.
There is no 'work bench' in Creo. There is part mode or assembly mode.
Wildfire:
Select component  View > Display Style > Transparent
Creo:
Select component then either
model tab > model display pulldown > component display style > transparent
view tab > model display pulldown > component display style > transparent
Re: Difference between Distance*D Offset*O
Please elaborate.  What are you referring to?
IN chamfer.. D*D and O*O i want to know the difference.
