Unable to exit PTC Creo Parametric.
  • August 8, 2016
  • 3 replies
  • 3671 views
When I'm tring to exchange Current Workspace or Exit the Application, then CREO is showing this messagebox.
I couldn't found any answer.
What's this Troubleshooting?
How can I fix it?
Please help, Thanks.
Best answer by BenLoosli
It means the transfer of data from Creo to your PDM is not complete.
Usually occurs with a large assembly that you are saving with automatic upload or checking in.
BenLoosli23-Emerald IIIAnswer
배상현1-VisitorAuthor
Yes, Thank you ^^
When I finished wrote the this question, CREO was wokring.
I have just waiting. It's all.
(That was a large assembly, yes.)
In my case it's not a large assembly.
I simply loaded my .asm without any other PDM operation
and after many minutes CREO2 is still locked !
Pier
