Unbend
  • January 23, 2016
  • 12 replies
  • 4772 views
         how to unbend this part any one guide.
kind regard,
Best answer by SergeyGvozd
Hello!
It is necessary to do a little differently.
See the attached file.
@ I'm sorry for my english
repeat making your part using extrude and extrude but use the sheetmetal template.
Then use Sketched Rip feature, and unfold/flat pattern will work.
aminhas14-AlexandriteAuthor
I can't did you work on file than I will able to see?
I did convert your file and it did work.  The thickness has to be consistent and you must create a rip feature to make it unfold.  If you start with a sheetmetal part, it will work fine.
Hello!
thank you!
