using CFD IN CREO PARAMETRIC
  • March 4, 2015
  • 6 replies
  • 5758 views
is it possible to make CFD analysis by creo for example for the nozzles analysis . if it possible i need any pdf book talking about this matter
Best answer by AndyHermanson
There is no fluid flow available from PTC today. Others like ANSYS or Simulation CFD allow you to integrate with versions of their software, but you need to buy licenses from them.
Ansys has a module that can be integrated with Creo using Ansys Workbench. and there are other stand-alone analysis tools
deia_20081-VisitorAuthor
how to add this module and how to deal with it? thanks for reply
Buy a license from Ansys.
We create all models in Creo Parametric and use CFD software from Novus Nexus for meshing
The software is called "Fluid Nexus" and I highly recommend it.
