VBA-API change active sheet
  • February 21, 2018
  • 2149 views
 Hello.
I would like to change the active sheet on a drawing using VBA-API, but I can't find any way to do it, I'm new to VBA-API. The best I cold manage was to use macro to change sheets, which worked, but did produce somr undesired effect.
The documentation states "You can regenerate a sheet only if it is displayed.", so it must be possible to change  the displayed sheet.
My code so far
Public Sub change_sheet_parameter()
 Dim conn As IpfcAsyncConnection
 Dim cAC As CCpfcAsyncConnection
 Dim session As IpfcBaseSession
 Dim model1 As IpfcModel
 Dim sheetData As IpfcSheetData
 Dim sheetowner As IpfcSheetOwner
 Dim sheetInfo As IpfcSheetInfo
Set cAC = New CCpfcAsyncConnection
Set conn = cAC.Connect("", "", ".", 5)
Set session = conn.session
Dim oModelDescriptorCreate As New CCpfcModelDescriptor
Dim oModelDescriptor As IpfcModelDescriptor
name_w = "SHM-7457-004.drw" 'Name of the drawing
 Set oModelDescriptor = oModelDescriptorCreate.Create(EpfcMDL_DRAWING, name_w, Null)
 Set model1 = session.RetrieveModel(oModelDescriptor)
 Set sheetowner = model1
 Dim oWindow As pfcls.IpfcWindow
 Set oWindow = session.OpenFile(oModelDescriptor)
 oWindow.Activate
Set sheetInfo = sheetowner.GetSheetInfo(1)
test_ = sheetInfo.Height
MsgBox test_
'The part where I would like to change the displayed sheet.
sheetowner.RegenerateSheet (1)
End Sub
Best answer by mvitárius
So the answer was in the tutorials for VBAPI in the pfcDrawingExample.vb
In the "Create drawing views" example it clearly shows what command to use.
 'Create drawing views
 'Function : createSheetAndViews
 'Purpose : This function adds a new sheet to a drawing and
 ' creates three views of input model.
 Public Sub createSheetAndViews(ByRef session As IpfcBaseSession, ByVal solidName As String)
 Dim model As IpfcModel
 Dim solidModel As IpfcModel
 Dim drawing As IpfcDrawing
 Dim sheetNo As Integer
 Dim modelDesc As IpfcModelDescriptor
 Dim matrix As CpfcMatrix3D
 Dim i, j As Integer
 Dim transF As IpfcTransform3D
 Dim pointLoc As IpfcPoint3D
 Dim genViewInstructions As IpfcGeneralViewCreateInstructions
 Dim proViewInstructions As IpfcProjectionViewCreateInstructions
 Dim view2D As IpfcView2D
 Dim outline As CpfcOutline3D
 Try
 'Get current model and check that it is a drawing
 model = session.CurrentModel
 If model Is Nothing Then
 Throw New Exception("Model not present")
 End If
 If Not model.Type = EpfcModelType.EpfcMDL_DRAWING Then
 Throw New Exception("Model is not drawing")
 End If
 drawing = CType(model, IpfcDrawing)
 'Add new sheet to drawing
 sheetNo = drawing.AddSheet()
 drawing.CurrentSheetNumber = sheetNo
 'Find the model in session or retrieve from disk
 modelDesc = (New CCpfcModelDescriptor).CreateFromFileName(solidName)
 solidModel = session.GetModelFromDescr(modelDesc)
 If solidModel Is Nothing Then
 solidModel = session.RetrieveModel(modelDesc)
 Throw New Exception("Unable to load Model " + solidName)
 End If
 End If
 'Add the model to drawing
 Try
 drawing.AddModel(solidModel)
 Catch ex As Exception
 Throw New Exception("Unable to add Model " + solidName + " to drawing")
 End Try
 'Create a general view from the Z axis direction at a predefined
 'Location
 matrix = New CpfcMatrix3D
 For i = 0 To 3
 For j = 0 To 3
 If i = j Then
 matrix.Set(i, j, 1.0)
 Else
 matrix.Set(i, j, 0.0)
 End If
 Next
 Next
 transF = (New CCpfcTransform3D).Create(matrix)
 pointLoc = New CpfcPoint3D
 pointLoc.Set(0, 200.0)
 pointLoc.Set(1, 600.0)
 pointLoc.Set(2, 0.0)
 genViewInstructions = (New CCpfcGeneralViewCreateInstructions). _
 Create(solidModel, sheetNo, pointLoc, transF)
 view2D = drawing.CreateView(genViewInstructions)
 'Get the position and size of the new view
 outline = view2D.Outline
 'Create a projected view to the right of the general view
 pointLoc.Set(0, outline.Item(1).Item(0) + (outline.Item(1).Item(0) _
 - outline.Item(0).Item(0)))
 pointLoc.Set(1, (outline.Item(0).Item(1) + outline.Item(1).Item(1)) / 2)
 proViewInstructions = (New CCpfcProjectionViewCreateInstructions). _
 Create(view2D, pointLoc)
 drawing.CreateView(proViewInstructions)
 'Create a projected view bellow the general view
 pointLoc.Set(0, (outline.Item(0).Item(0) + outline.Item(1).Item(0)) / 2)
 pointLoc.Set(1, outline.Item(0).Item(1) - (outline.Item(1).Item(1) _
 - outline.Item(0).Item(1)))
 drawing.Regenerate()
 MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
 End Try
 End Sub
mvitárius15-MoonstoneAuthorAnswer
 Dim i, j As Integer
 Try
 End If
 End If
 End If
 End If
 Try
 End Try
 'Location
 For i = 0 To 3
 For j = 0 To 3
 If i = j Then
 Else
 End If
 Next
 Next
 End Try
 End Sub
