2-Explorer
February 20, 2019
Version of Creo File
  • February 20, 2019
  • 8 replies
  • 7790 views
Hello
I am having Creo 4.0 M030. I would like to know version of CAD file opened in Creo. For example, I have opened a.prt.2 into Creo, how can I come to know that it's 2 version file opened in Creo? On Creo title menu, it just displays a.prt.
Note : Please do not get confuse with config option "save_file_iteration". This is to decide whether to create new version on each save or not for part file. What I need is to know version (.31 or .32 for example ) for an opened part file in Creo.
Thanks and Regards
Ketan
Best answer by MartinHanak
try following config.pro option to display full path to model in window title
display_full_object_path yes
StephenW
I don't know of a way within Creo but if you look at the .prt file in a text editor, you can tell what Creo release and build code the file was last saved in.
2-Explorer
February 20, 2019
Hi
I am not looking for Creo version and build code. I am expecting Creo CAD file version.
f you go to the Tools tab and select Investigate, File History. In the upper left hand corner it will show model name and Version
2-Explorer
February 20, 2019
Perfect. This is what I need to know for a CAD file.Thanks a lot.
I am wondering why this version (.32 or .33) is not displayed on Creo title bar as abc.prt.32 ? It shows only as abc omitting extension (.prt) and version (.32) details... Earlier I have seen title of Creo model window showing abc.prt.32. Am I missing some config option or setting for this?
Patriot_1776
I have had the config.pro setting Martin mentioned for years, and from the verbiage in the list of options, that's it:
"Controls the display of the object's full file name
(including its object‐type suffix and its version number)
and file path in the window title and Model Info display.
Yes ‐ Displays full file name and file path. No ‐ Displays
object name only."
My header bar always shows me the version, and the state (e.g. WIP).
2-Explorer
February 21, 2019
thank you all for responding on this. Config option was the one which I could not recall.display_full_object_path worked.
