what causes relations to or not to truncate
  • November 8, 2017
  • 15 replies
  • 5495 views
Why would the relations automatically truncate in the first image, but not truncate in the second image?image 1image 1
image 2image 2
Sometimes it won't wrap until the model is closed, removed from session, and reopened.  Does doing that make any difference?  What about saving a copy?
SYNDAKIT15-MoonstoneAuthor
good observation but I have tried removing from session with making slight changes between:
  • replacing tab with space
  • different licences
  • editing the line
  • making the relations fail then editing
  • adding/removing spaces within equation
  • different sizes of relaion windows upon saving
  • using notepad as the relation UI
  • using the new relation editor as the UI
It is very annoying because when the truncation occurs you can't just highlight the newly seperated lines that make up the right side of the equation and evaluate them. You must first re-format the equation to be only one line then you can evaluate it without getting an error.
Sounds like a bug.  Maybe open a support case if you have it.  If not, let me know and I will open one.
