What defines the Sketch Origin?
  • August 3, 2018
  • 5 replies
  • 3027 views
Hello All,
I am trying to create a pattern of extrusions around a curve (Sketched line loop). What I understand is that the pattern starts at the lines Origin!?  But I'm not sure how to control this origin.
I've tried starting the sketch at different points but the origin still seems to be pretty random.
Note: I have tried "Use alternate Origin" button in the pattern's options tab, but this creates a whole host of weird problems... Am I just not using this correctly?
Best answer by John.Pryal
Welcome to the 'wonderful world of Creo patterning'. A world of mystery & suspense. Will my pattern work or not work? Oh, it does, but not as i had hoped. Joking aside, I think I am right in saying that the first point clicked when defining the sketch becomes the start point (or origin) of the pattern curve. That generally works for me anyway.
Good luck!
John
Good luck!
John
Hi John,
Yes! It is a fascinating and strange world... One which usually helps me allot!
Thanks for the suggestion, I thought this should probably be the case (as it makes sense right?) but i'm still not having any luck with it. The little arrow that appears on the sketch still appears at a random point (Random as in; not where I started the sketch when I created it).
my only work-around is to find out where that point is (through starting a sweep or pattern feature and cancelling) and then creating the feature that I want to pattern at that point. (which does come with its own share of complications for certain shapes!)...
Thanks for the help, i'll keep playing and hopefully figure something out; thankfully this is the first time in my 2 years of using Creo that I've had to pattern along a curve, so it's not a regular thing for me!
Best Regards
Elliot F
Are you willing to up-load the part & i will have a look? If not, perhaps try replicate the issue on a dummy part & up-load that?
Best regards
John
