2-Explorer
August 3, 2017
What is flat hole
  • August 3, 2017
  • 4 replies
  • 3020 views
Hello
I know about through and blind hole. What does mean by flat hole in Creo?
Regards
Ketan
Best answer by BenLoosli
Maybe a hole with a flat bottom, instead of a drill point. Produced by using an end mill to clean out the material left by the drill point. Useful on thin material where you need to bottom tap the hole for thread engagement but can't have a thru hole.
Where did you read about a flat hole?
2-Explorer
August 3, 2017
In requirement document I received. I am actually into Creo Automation team using Toolkit. Not sure what is flat hole.
BenLoosli23-Emerald IIIAnswer
