Where are the old Notes that you would creat thru the Setup menu located now in Creo 3?
  • December 7, 2016
  • 1578 views
Hoping someone can point me to where the old notes that you would create in models and assemblies thru the setup menu are now located?
If you look in the Pro/E Rev 18.0 Fundamentals softback book on page 17-12 you will see what I'm looking for.
You use to be able to go Set Up > Add : from the Model Notes menu.
These notes are not displayed in the model or assembly. They are more like system level notes that you can created which are assigned a Note ID number
that you can reference in a note that's added to a drawing. I use them once in a while to add reminders related to meshing setup for simulate.
Don Anderson
Best answer by DG_895068
still using creo2 here...but...maybe the same in creo3
look under Annotate tab in Annotations
it brings up the (much missed) Menu Manager
DG_8950681-VisitorAnswer
