Why does my spool name make a new table row?
  • September 29, 2016
  • 2 replies
  • 1625 views
I'm trying to use a repeat region in a table on my drawing to show info about a harness. I've gotten everything set up and the length, connector name and wire name all populate as you would expect. My problem comes when I try to put the spool name in. For some reason, the name comes up, but it creates a new row and comes up in the new row all by itself. So, all of the other cells in the row fill with name, length, etc. but the spool name pops up on a row below them all alone. Anyone have any clue why this is? Thanks
Best answer by ykhessin
Hi Susan,
It probably happens because you are using harn.run.len , harn.run.name etc repeat region parameters for all rows but in order to display spool information you are using spool.name parameter.
Using harn.run.spool.name repeat region parameter should solve the issue.
Yakov.
ykhessin5-Regular MemberAnswer
Hi Susan,
Yakov.
smandel1-VisitorAuthor
Thank you so much!
