3-Newcomer
Radial (Centrifugal) Fan in Creo Flow Analysis
I am using creo flow analysis (creo 11.0.4) with the base license.
I would like to simulate a free standing centrifugal (radial) fan in a simple air channel.
How do I simulate that?
I can create a fluid volume and at the locus of the fan I create a circular interface. I can now choose "fan" for that interface and add a local function as a dp-curve. So far so good. However, creo considers that fan automatically as axial fan and, therefore, the fluid flows straight through this interface. I could add swirl (radial and tangential velocity) to the fan, but I have to add these values in m/s (and I don't know these). Furthermore, I can not select the rotation direction. I saw that alternatively I could choose "rotating wall" as boundary condition if I have a solid that represents the fan blades but I could not manage to create a fan with that. I am also not interested in the flow right through/in the fan but rather through the whole channel. What is the difference between "rotating wall (boundary condition)" and "fan (interface)"?
Many thanks for the help.
Philip
Do I need a plus or premium license to simulate a
Emeritus
Hi @PC_10446540,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best Regards,
Vivek N
Community Moderation Team
Hi!
A good resource for the setup of any simulation with rotating components would be the Mixing Tank tutorial be found in the Creo Online Help Center: https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/tutorials_pma/Mixing_Tank_Overview.html#wwID0EFJEV
The Fan condition you'd found other Interfaces is great for system level modelling where the fan can be replaced with a simpler fan curve calculation saving on simulation complexity and time.
Modelling rotating or translating geometry does require the Moving/Sliding mesh capability found in the Plus package.
Emeritus
Hello @PC_10446540,
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
