Create Your Application UI - Video Guide
Watch a video tutorial on utilizing the Mashup Builder to create a User Interface (UI) for your IoT application.
Guide Concept
This project will introduce the ThingWorx Mashup Builder through the use of an instructional video.
Following the steps in this video-guide, you will learn how to use this tool to create a Graphical User Interface (GUI) for your IoT Application.
We will teach you how to rapidly create and update a Mashup, which is a custom visualization built to display data from devices according to your application's business and technical requirements.
You'll learn how to
  • Create new Mashups
  • Choose a Static or Responsive layout
  • Add Widgets to your Mashup
  • Bind data Services to Widgets in your Mashup
  • Create a functional GUI with applied usage of Widgets and Services
NOTE: The estimated time to complete this guide is 30 minutes
Step 1: Video
Click the link below to enjoy the video. You may set the video to full screen by clicking the button in the bottom-right.
If you're following along within your own ThingWorx environment, you may wish to pre-download and extract the attached MBQS_Entities.zip file. It will be used in the later half of the video as a backend data simulator.
Step 2: Next Steps
Congratulations! You've successfully completed the Video Guide - Create Your Application UI, and learned how to:
Learn More
We recommend the following resources to continue your learning experience:
Capability Guide
BuildData Model Introduction
ExperienceObject-Oriented UI Design Tips
Additional Resources
If you have questions, issues, or need additional information, refer to:
Resource Link
CommunityDeveloper Community Forum
SupportMashup Builder Support Help Center
