B@J 10e statics 4-99.xmcd
  • July 24, 2011
  • 3 replies
  • 2233 views
Just a simple 3 -D statics problem worked using Mathcad vectors.  If you can get students comfortable with vector arithmetic this form of the solution can save time and confusion.
How do I convert this to Prime 2.0?
Thank you!
Joeboy1-VisitorAuthor
open prime 2, go to getting started, go to migration guide, follow the instructions.  Warning - the result will probably not be pretty, I use "insert math region" alot in my docs and prime 2 does not accept it.  You would be better to leave it in 15
Thanks, Dixie.
Since the instructions start with loading Mathcad 15 anyway, I took your advice and left your file in 15.
Well done example!  I look forward to going through it in detail!
