computing precision
  • January 11, 2010
  • 3 replies
  • 3351 views
need more than the usual (Pentium?) 16-digit precision, at least 32, 64 would be better (working with 10**100 numbers ...) - anybody know how to set?
>how to set?
____________________________
Results with more digits than the numbers processed is meaningless. The conventional Pentium 16 machine precision does process at the floating point 20/21. Whether symbolic will display > 21 digits or not ... the pentium will take only 20. The 16 "true" Pentium machine precision represents the radius in cm of the electron seating at the top of a tower 2818 m height. Assuming all your numbers are known at 40 digits, about no symbolic results will be > 20 (floating arithmetic).
"The Accuracy of a machine real number depends on the value of $MachinePrecision on your computer."
Guide line:
There are plenty more culprits in numaccuracy !
jmG
You can use the symbolic processor to do higher precision arithmetic.
Richard
foxbat1-VisitorAuthor
thanks, Richard!
