Function will not converge
  • October 22, 2013
  • 20 replies
  • 24573 views
I am calculating dynamic pressures on a moving gate and cannot get the integral for vertical force Fv(t) to converge. I have tried adjusting the convergence tolerance but this does not seem to make any difference. Any clues would be appreciated.
Cheers
Ross
See if the attached helps.
Alan
remslie14-AlexandriteAuthor
Alan,
Yes indeed your modification did help. If I now take this function and wish to use it in an Odesolve block as the final step I hit the wall with another error. Any clues to de-bug this would be appreciated.
The problem I am trying to solve can be unstable with divergent response, however, it should be stable and converge when the damping (zeta) is a modest value (i have used 0.05 or 5%).
Thanks again
ross
Ross
The attached works - the ODE solver worked ok, it was just the plotting that confused it (because of a previously defined set of t's).
However, I notice that the solve block contains M(t), which is a function of Fv(t), which is in turn a function of pp(t,y), which is a function of dtheta/dt - in your case a previously set function of dtheta/dt, not the one you are currently solving for within the solve block. Is this what you intend?
Alan
Edit. Also, it is a function of theta, through F(t,s). Again this isn't the theta that the ODE block is solving for. Is this right?
