See if the attached helps. Have concentrated on your question about y being a scalar as you expected a vector. The magic is done by using the vectorize command from the matrix palette.
Maybe looking at http://communities.ptc.com/message/197133#197133 can help to get a better fit. On the other hand, as far as I see, you are trying a simple exponential fit (a*e^b*x) and I doubt that thats appropriate.
I was confused by some action you did in that sheet and its a little bit messy, so maybe I overlooked some detail.
OK. I will try to think more. Thank
Hi . Please why I could not see the value of f(x,ag) when I evaluate. when I do the operation I - f(x,ag) I don't have a result. This is because of the function f(x,ag).
thank
