How to read value of a matrix into a loop
  • March 4, 2011
  • 6 replies
  • 4175 views
I want to make a program that will test the value of h above, h is a matrix containing (1, 4, 11, 7), starting from top to bottom (1 then 4, 11, to 7), if h > 10, then stop the loop, when h is still less than 10, then the value of s will add to 1 and stop only when the condition is met. then extract the value of s into "section". What is possibly wrong or missing in my program.
Pls see the attach mathcad file. Thank you for your help
Have a look at the attached.
Remember ORIGIN = 0.
Mike
Bartz871-VisitorAuthor
Thank you very Mr. Armstrong
That really help....now I can program what I have in mind
You know I'm new to MCAD but i'm really interested in learning more
Thank you again for your help
No problem at all. I have shown how this can be achieved using a for loop and Alan has shown the while loop method. A good starting point would be to learn the two different methods and understand the differences between them.
Read through the forum and ask questions when your stuck - basically teach yourself and learn from others that's the best way to learn.
Mike
Hi Mr Stevens,
I've used your idea of the while loop in my program, but I have a problem. Pls see the attach MCAD file.
Neptali Barte wrote:
Hi Mr Stevens,
You need to include Fe etc inside the while loop.
Alan
