amcgough
Oct 14, 2026 2:08 AM UTC
How do I use a plus/minus (±) operator in Mathcad Prime?
  • Oct 20, 2026 7:39 PM UTC
  • 99 views
  • Translate All
Scenario / Question
How do I use a plus/minus (±) operator in Mathcad Prime, and does Mathcad Prime include a built-in ± operator?
Overview
Mathcad Prime does not include a built-in ± plus/minus operator that can be used as an infix operator in expressions. A workaround is to define your own function that returns the positive and negative variations of a value, but it must be used as a function with parentheses rather than as a true ± operator.
Step-by-Step
  1. Determine whether you need a display symbol or an operator: A ± character can be displayed using supported Windows fonts, but this does not provide mathematical operator functionality.
  2. Create a custom function: Define a function that represents the plus/minus behavior you need.
  3. Use the function in prefix form: Call the function using standard Mathcad Prime function syntax with parentheses around the argument.
  4. Evaluate the result: The function can provide equivalent plus/minus behavior, but it cannot be used as an infix ± operator within an expression.
Key Notes & Limitations
• Mathcad Prime does not provide a built-in ± infix operator.
• A ± symbol can be displayed as text if supported by the selected Windows font.
• Displaying the symbol does not add mathematical functionality.
• Custom functions can be created to mimic plus/minus calculations.
• Custom plus/minus functions must be used in prefix form with parentheses.
• The infix operator approach available in earlier Mathcad versions is not available in Mathcad Prime.
Related Questions (FAQ)
Q: Does Mathcad Prime include a built-in ± operator?
A: No. Community experts confirmed that Mathcad Prime does not provide a built-in ± operator for use within mathematical expressions.
Q: Can I insert a ± symbol into a worksheet?
A: Yes. A ± character may be displayed using fonts supported by Windows, but it serves only as a visual symbol.
Q: Can I recreate plus/minus behavior in Mathcad Prime?
A: Yes. You can define a custom function that returns the positive and negative variations required for your calculation.
Q: Can the custom function be used exactly like an operator?
A: No. In Mathcad Prime, the workaround must be used as a function with parentheses and cannot be used as a true infix ± operator.
Links & Resources
PTC Source Community Thread: +/- Plus/Minus sign Mathcad Prime? | Community
Related Links:
Is it possible to add plus minus symbol in math field? | Community
How to do plus and Minus sign in Mathcad Prime 4 | Community
Symbolic operator in solve block | Community
This article is part of a new community content management program to bring more visibility to popular posts on the community.  It has been reviewed for accuracy by Andy McGough, Product Management Director.
    23-Emerald I
    Oct 26, 2026 11:16 AM UTC
    Does this mean that “infix”, “prefix” and “postfix” will not be implemented in Prime?
