I'm having a lot of issues with learning to use Creo and very frustrating.
  • August 28, 2026
  • 40 views
I have fastener holes on a curved feature that looks likes it was created with a resolve. I checked the fastener hole edge curves on both sides of this feature, which is nonplanar. One side of the hole is made up of two split arc edges. The other side of the hole is made up of two spit spline edges. The spine edges is an issue in creating a fastener in Simulate. I tied to use the Round to edit the spines but if this is the correct tool I can’t figure out how to replace the spine edge with arc edges.
Does anyone know the approach to doing this? I only have the Creo Parametric not any advanced design add-on licenses.
der_Wolfgang
May be you might wanna ask your question in a more matching forum like:  https://community.ptc.com/t5/Creo-and-Creo-Parametric/ct-p/creoparametric
Creo Parametric should not be confused with Creo Elements/Direct Modeling, formerly named CoCreate SolidDesigner CAD Products.  You posted your question in the section for Creo Elements/Direct Modeling section.The chance of getting helpful answers is better using an appropriate forum/section!
● cad.de + osd.cad.de ● java-forum-stuttgart.de + jugs.de ● notepad-plus-plus.org ●
