DomenicLaritz
Missing URL redirections after migration to new platform
In our internal company documentation, I was able to find 24 ideas that are no longer accessible under the previous URL.
I’d have expected the migration team to set up a URL redirection so that users automatically land on the new page!
  1. Idea: Ability to copy component name from the assembly model tree
  2. Idea: Improve the Symbol Definition Interface
  3. Idea: Start with CreoView Lite and if needed toggle to get MCAD without exiting the tool
  4. Idea: Possibility to adopt the Windchill login credentials in Toolkit apps
  5. Idea: Easier Measure in Creo View
  6. Idea: Configurable links via REST API
  7. Idea: Change the default font for Sketch
  8. Idea: Suppress selection window for Top level instance having only one instance linked to the contents
  9. Idea: enhance "Set New Name"-functionality in Save As wizard to set a new number in a number pattern
  10. Idea: Add tree columns in Creo Illustrate like in Creo View
  11. Idea: "Add by Number" search field should show the search results always in the same order
  12. Idea: pre-define an activated "Show in Groups" for a specific column in a query builder report template
  13. Idea: Allow Intelligent Fastener Extension (IFX) to assemble Nut only
  14. Idea: Improve window size / scroll areas with ECN affected / resulting objects => separated tabs
  15. Idea: 'Replace' actions should also be available in Part Uses Table.
  16. Idea: A separate field / attribute for the Change Notice TEMPLATE NAME is needed.
  17. Idea: Enable possibility to assign tasks directly to groups or multiple users
  18. Idea: Create Change Request templates in Windchill 11
  19. Idea: Define a preferred context while creating a new workspace
  20. Idea: ModelCheck: Add check to define standard list for view scale in drawing
  21. Idea: Scale an inset to specific value
  22. Idea: It Should be possible to Customize the Table View in the 'Collect Objects' Table.
  23. Idea: Config.pro option to NOT display the "Resource center" when launching Creo3
  24. Idea: Add a Pro/Toolkit function to identify weak model dimensions.
Catalina
Community Manager
Hi ​@DomenicLaritz
Thanks for drawing our attention to this!
URL redirection is a feature of the migration and we made sure to check that it is in place. We’re going to look into why your links do not redirect and get back to you with an update as soon as possible.
Thank you and best regards,
Catalina | PTC Community Manager
AndrewK
Community Manager
Hi ​@DomenicLaritz
Thanks for reporting that. The redirects to the initial Idea posts were working but redirects to their comments which had different ids were missed! These should all be working for ideas and discussion posts now and the tips articles will likely be done next week.
DomenicLaritz
Hello ​@AndrewK,
thanks for the explanation and the fix.
For most of the ideas I listed above, the redirect is now working.
🚧 But for the 13th and 19th it still doesn't work. 🚧
AndrewK
Community Manager
Ok thanks ​@DomenicLaritz I will take a look and see if they can be fixed.
