3-Newcomer
June 2, 2024
Generic tolerance class in drawing
  • June 2, 2024
  • 2 replies
  • 1278 views
Hello, I am using Creo parametric educational/academic edition 10.0.1.0. When I go to File>Prepare>Model Properties I scroll down to the "detailing" section and see "Tolerancing standard" set to "ISO/DIN Medium" and "Tolerancing standard verison" set to "ISO 1101:2017".
I would like to have this information in a drawing, so that the drawing updates if I set it to "coarse" for example. I am aware that it sets the tolerance table for general tolerances, and that I can use it to automatically display tolerances in a dimension in a view.
Is there a way to include the values of theese model properties (tolerance class) in a note or repeat region?
Or a way to read them into or from a model parameter?
I have searched the forum, the reference and the web for answers but found nothing on the matter.
Best answer by BenLoosli
I don't think that information is available for inclusion in a drawing note.
You will need to open an Idea to get this added to the list of proposed enhancements.
Community Moderator
June 7, 2024
Hi @JR_10772660
Thank you for your question.
Your question appears to be  well documented, however I'd like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
BenLoosli23-Emerald IIIAnswer
