Mar 22, 2024 1:23 AM UTC
unable to edit dimensions in sketcher mode - student license
Hi All,
I have a student license and from past 2 days i get the below error in sketcher mode when i try to update the dimensions. It doesn't allow to modify any of the dimensions in sketcher mode.
"When a constraint is active, right click to cycle through lock/disable/enable the constraint. Use Tab key to toggle active constraint. Press and hold Shift to disable snapping to new constraints."
Kindly support as i am unable to work.
Thank you.
Mar 22, 2024 7:52 AM UTC
did you ask another student?
StephenW
Mar 22, 2024 10:39 AM UTC
@PK_10540520
I'm not sure if this is your problem specifcally, but the issue seems to have come up a lot
https://community.ptc.com/t5/3D-Part-Assembly-Design/Can-t-enter-dimensional-value-after-double-click-in-model-sketch/m-p/857392
Emeritus
Apr 1, 2024 6:08 AM UTC
Hello @PK_10540520,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
