Add Style to Your UI with CSS Part 2
- 0 replies
- 1050 views
- Translate All
Step 8: Troubleshooting
Issue Resolution
| CSS does not seem to be applied to the Mashup. | Verify your CSS is included in the runtime TWX CSS. Clear Browser cache if your CSS is not merged to the combined TWX CSS. (under debug mode: Hold refresh button->Clear Cache). |
| TWX fails to import the extension. | If the extension is already installed, but you made recent changes, you need to bump the Version number in the metadata.xml. |
| Recent CSS changes are ignored. | Clear browser cache if your CSS file has changed recently. |
Step 9: Next Steps
Congratulations! You've successfully completed the Add Style to Your UI with CSS guide, and learned how to:
- Create custom CSS classes using the integrated CSS editor
- Bind CSS classes to a Mashup and to individual Widgets
- Use Media queries to dynamically apply styling
Learn More
We recommend the following resources to continue your learning experience:
Capability Guide
| Build | Application Development Tips & Tricks |
| Experience | ThingWorx Application Development Reference |
Additional Resources
If you have questions, issues, or need additional information, refer to:
Resource Link| Community | Developer Community Forum |
| Support | Help Center |
