Learning Path - Connect and Monitor Industrial Plant Equipment
- August 4, 2022
- 0 replies
- 5694 views
Connect and Monitor Industrial Plant Equipment Learning Path
Learn how to connect and monitor equipment that is used at a processing plant or on a factory floor.
NOTE: Complete the following guides in sequential order. The estimated time to complete this learning path is 180 minutes.
- Create An Application Key
- Install ThingWorx Kepware Server
- Connect Kepware Server to ThingWorx Foundation
- Create Industrial Equipment Model
- Build an Equipment Dashboard
