18-Opal
September 26, 2017
about Tomcat's manager Deploy
  • September 26, 2017
  • 4 replies
  • 2889 views
Hi
For some personal reason, I have reinstalled Thingworx.
I made a document of the process that I had previously installed, so I proceeded to install it by referring to the document.
Strangely enough, however, Deploy will stop Tomcat in 1-2 seconds
If i delete ThingworxStorage and backup space in the root folder and delete Thingworx in Tomcat's webbase, Tomcat will run again.
However, when you deploy Thingworx, it stops.
Thingworx used ThingWorx-Platform-Postgres-7-3-10,
Version of Tomcat 8.0.45
jdk is 1.8.0_131 jre is also 1.8.0_131
The operating system is Windows 7.
Simple ThingWorx-Platform-H2-7-3-10 is good for Deploy.
I have attached a setup ppt document that I created.
Thank you for your solution to this problem.
Best answer by posipova
Have you deployed Thingworx.war through the webbrowser or copy/pasted into the webapps folder of Tomcat directory?
I'm a bit confused, is this powerpoint you created during this installation or previously and now followed? I see there are only 9 tables in the pg admin III, but it should be around 57 when both scripts execute properly. I also see that you can access the composer in the powerpoint, so the installation there is successful.
Hi Seonho Cha,
Please share your Application log and the Catalina log files. Does your ThingworxStorage and ThingworxPlatform folders have Read/Write permissions?
CHASEONHO18-OpalAuthor
18-Opal
September 27, 2017
Hi Janet Joseph Antony Dass
I think this is the problem when I think!
I can not try it right now, but I have to run it on another PC.
Or I'll try it on VMware
posipova20-TurquoiseAnswer
20-Turquoise
September 26, 2017
18-Opal
September 27, 2017
Hi Polina Osipova
There are 57 tables in pgAdmin
Nine of these shown are made through schema updates.
