Adding a Thing to a Network
  • July 15, 2015
  • 2 replies
  • 2132 views
I am trying to add a Thing to a network programatically,
It is intended in this case to add a parent
var params2 = {
    to : SiteName,
    connectionType : undefined
Networks['CustomerNetwork'].AddConnection(params2);
When tested I get an error about invalid connection type....  I however can not find a resource which lists valid connection types
    Best answer by michaele
    I seemed to have found a or the solution...   The connectionType appear to be Parent, Sibling or Child,  though I haven't yet tested all 3, At the very least Sibling works.  And I have been able to add a thing to a network in this way
    michaele1-VisitorAuthorAnswer
    Actually you can leave connection type as undefined by not even declaring it in the JSON parameter block, otherwise use contains.
