Adding getProperties() service of value stream programmatically
  • August 13, 2016
  • 3 replies
  • 2203 views
I would like to know, is there a way to add getProperties() service to Mashup through Script in thingworx 7.2.
Penchalaiah
Best answer by PaiChung
I think the easiest way is to have the necessary valuestreams created ahead of time and associated with the ThingTemplate(s)
We recommend minimizing the number of valuestreams, generally a single valuestream per ThingTemplate.
22-Sapphire I
August 15, 2016
Can you please explain what you are looking to do with that and in what form?
Sounds like you want to dynamically create valuestreams and have that information come into a mashup programmatically??
pyekula1-VisitorAuthor
Yes I would like add value streams dynamically
PaiChung22-Sapphire IAnswer
22-Sapphire I
August 16, 2016
