Alert and notification
  • July 13, 2016
  • 11 replies
  • 4645 views
Hi ,
I want to send an alert in the following format to the recipient. We are using mail server extension
Dear abc@gmail.com,
An alert has been triggered from gmail which requires your attention. Please see below for details of the alert.
king: abc
Rose: abc fdeg
asdf: First Pass
Met: <40%
trpu: 32%
Time: 2016-July-12 11:15:01
Recipients: abc@gmail.com,def@gmail.com
This is an auto-generated email  that does not accept responses. For more detailed information, login to sc.abc.com/*aditya. If you require additional help, please reach out to your leader or submit a ticket here.
Aditya Kumar
    July 13, 2016
    Please give the answer asap.
    Aditya,
    Please provide additional information on what you are trying to do and what you have implemented thus far. Have you created the Alert yet, have you constructed the custom service that will generate that message in that format? Where are you trying to pull those values from you've cited in the message?
    Meghan
    July 13, 2016
    Hi Megan,
    Yes we have created the alert and the alert is also going. We were only sending "Alert" to the recepients.
    But, now we have to send all the below details:
    Dear abc@gmail.com,
    king: abc
    Rose: abc fdeg
    asdf: First Pass
    Met: <40%
    trpu: 32%
    July 13, 2016
    That to in the same format mentioned above.
    Font should also be same. How to configure in the service
    Hi Aditya,
    You can't write HTML code directly on the scripting box, you should write it on a String, something like this:
    var myHTML = "<html><head></head><body>\
    <h1>Title</h1>\
    Content bla bla bla <i>italic</i>\
    </body></html>";
    the use myHTML to pass as the parameter on the mail extension.
    Exactly.
    July 14, 2016
    Thanks Meghan and Carles.
    It is working now.
    Hi Aditya,
    How did you manage to configure your alert to send messages? Please explain. I created an alert on a property. And my mail is also configured.
    Wasim
    Hi Wasim Ahmed​,
    Create a subscription to subscribe to this alert. In the Subscription code; use the SendMessage service of the mail Thing to send the mail.
    Do let me know if you face any issue.
