Best practise to store historical data plus live streaming data in a Thing
  • October 4, 2017
  • 12 replies
  • 8245 views
What should be the best practice to store the historical data from Excel and then later start storing Live streaming data in same properties of a Thing. I know as per the documentation, I should use Datatables to store static or historical data and Value Streams for Live streaming data but my setup is different. Initially, I need to push some Historical data of a device and later the same device will start pushing live data in TW. I am not sure how would I proceed to achieve this.
Please suggest me the best way possible.
Thanks in advance.
Best regards,
Neetu
Best answer by nagrawal-2
Hi Carles,
I have resolved the issue. It's not about passing the date-time value in CSV, I had to change the date format in params object:
dateformat: "yyyy-MM-dd HH:mm:ss"
The string should be in exact above format (Case sensitive) to make it work.
Thanks for your support.
Neetu
If it's the same data that will be recorded live, than all have to go to the same storage, in this case Stream or ValueStream.
Hi Carles,
Thanks for your response.
Yes format of data will be same when recording live. But initially I will be pushing the data from CSV ? Can I push the CSV data in Value Stream?
Neetu
Yes for sure, you can read CSV files with the following extensions:
An you can insert data directly on the ValueStream with property owner Thing service:
  • Add+baseType+ValueStreamEntry
We usually combine booth without issues.
