Can I know where error occurs?
  • January 10, 2018
  • 2 replies
  • 2028 views
Hi all.
I think it is a widget error.
When mashup opened, It occurs error message that '"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx" opened with error(s).'
Can I know the widget which occurs error from the error code?
then, How can I know the widget?
Thank you.
Best answer by CRArko
Hello, Kiyong Park.
Typically we'd look through the application log to get some context and then try to pinpoint the cause of the error. If you can comfortably attach the log we can take a look through it. Also perhaps a screenshot of the mashup.
-- Craig A.
CRArko5-Regular MemberAnswer
Hello, Kiyong Park.
-- Craig A.
kpark11-VisitorAuthor
Hello, Craig Arko.
I solved this problem from f12(Developer Tools).
Thank you for your pleasure.
-kiyong
