Current time in a service
  • December 9, 2015
  • 3 replies
  • 8496 views
Hello all,
I have what seems like it should be a simple question, but I cant seem to find the answer to it.  I have an event that triggers a subscription.  I have with it the start time of a cycle of a machine, and I would like to get the cycle duration.  I am not being sent up the cycle stop time, so I am going to have to use the current time-cycle start.  How can I get the current time in my service?  I have tried
var currentdate = new Date();
var result=currentdate.getDate()
and it gives me a time in 1969 haha.  Is there an easy way to get the current time stamp?  It should be easy because anytime a property is logged it is used, but I am stumped!
Thank you!
Best answer by byutz
Just found the answer!
var currentdate = Date.now();
byutz1-VisitorAuthorAnswer
Just doing this also works:
var now= new Date();
result=now;
Thingworx 5.0+ get current date and time using Javascript source code
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS218294
