Dashboard is it possible to have more than one per user?
  • August 18, 2016
  • 9 replies
  • 4344 views
If I make two different mashups and in each mashup I insert a dashboard, I actually see the same dashboard and if I edit one, I'll edit the other one too.
Is it possible to have two different dashboards for to two mashups?
Best answer by ttielebein
Dashboards belong to the user who is logged in when creating them. If you logged in as another user and tried to view this mashup, you'd probably get an error. You'd have to share each tab individually with that other user before they'd see the right tabs. I would recommend logging in as different users for test and demo and creating different dashboards that way. You share by organizational unit, so if you only want some users to see some dashboards, you can share with different organizations and put different users in each organization.
Hope this helps!
Tori
Yeah, this should be possible. Just create two dashboards and two mashups and associate a different mashup with each dashboard
fmanniti1-VisitorAuthor
It's actually what I did but it doesn't seem to work.
I did this:
  • Create List of Gadget A
    • Gadget_a_1
    • Gadget_a_2
    • Gadget_a_3
  • Create a static mashup with all gadgets A included: "LibraryMashup_A"
  • Create a Mashup with dashboard and include LibraryMashup_A: Mashup_A
Then
  • Create List of Gadget B
    • Gadget_b_1
    • Gadget_b_2
    • Gadget_b_3
  • Create a static mashup with all gadgets B included: "LibraryMashup_B"
  • Create a Mashup with dashboard and include LibraryMashup_B: Mashup_B
Now, apparently, the two Mashups A and B have no relations, yet when I drag and drop the dashboard widget into Mashup_B I can see all Gadgets_A i previously made.
The only difference is that, when (runtime) I go on the group's menu and click on Add Gadget I see Gadget_b's instead of Gadget_a's; but if I edit Mashup_B I also edit Mashup_A automatically
Are you seeing the other dashboards as tabs when viewing them in the Mashups? Try unchecking the "ShowTabs" property of the dashboard widget on each mashup. I am looking at this in 7.1.0, and it appears to be working as expected. What you might be doing is modifying the same dashboard from each mashup without realizing that they are looking at the same tab of the dashboard widget. If this doesn't resolve your issue, let me know what version you are in so I can look for bug defects
