DateTime property on Users (via UserExtensions) is not persisting.
  • November 29, 2016
  • 4 replies
  • 2719 views
I am developing on Thingworx 7.0.3
I am having an issue setting DateTime property values on Users from within Java extension package code and having the data persist across Tomcat restarts
Even  in this simple example utilizing a service, the date will not persist over a Tomcat reboot.
However, if I set this value via Composer, it will persist across a Tomcat reboot.
@ThingworxServiceDefinition(name="Test", description ="")
  @ThingworxServiceResult(name="result", description="", baseType="STRING")
  public String Test() throws Exception {
  User usr = EntityTools.GetUser("myUsername");
  usr.setPropertyValue("LastSync", new DatetimePrimitive(DateTime.now()));
  return "finished";
I have also tried setting this via this line, as well, just to see, but with no change.
usr.setPropertyValue(DevicifyConstants.GLOBAL_PROPERTY_LAST_UPDATE_TO_SFDC, new DatetimePrimitive(DateTime.now().getMillis()));
Any ideas?
Best answer by
Sure enough this is a bug, and it is fixed by both 7.2.5 and 7.0.6
Jason Geiger​, Do you see the updated value in composer after running the extension service?
November 30, 2016
Yes. Everything looks great, until a Tomcat restart.
December 1, 2016
More info here, got some time to get back to this. I am beginning to suspect this is a bug so I will put in a case.
I've tried all three constructors for DatetimePrimitive, all accept the date and do not error but tomcat restart looses the data.
The final one, not mentioned above:
DatetimePrimitive dt = new DatetimePrimitive();
dt.setValue(DateTime.now());
usr.setPropertyValue(DevicifyConstants.GLOBAL_PROPERTY_LAST_UPDATE_TO_SFDC, dt);
I have tried initializing DateTime various ways but that is not it either.
I want to test this on 7.2.x to see if it's there but in the meantime I am going to put in a ticket.
Answer
December 1, 2016
