Default button in Thingworx?
  • February 1, 2016
  • 2 replies
  • 1994 views
Does anyone know if ThingWorx has a 'default button' feature? I'm talking about the ability to assign a 'default' button that is activated when Enter is pressed on a mashup (and you're not in a field that acknowledges Enter). Or a button that takes focus when a mashup is first presented, so that it is activated if the user presses 'Enter' immediately?
Best answer by PaiChung
Each Input Widget (Button included) has a Tab Sequence you can set, you can use that to give focus to an element like a button.
Plus of course improve usability.
PaiChung22-Sapphire IAnswer
22-Sapphire I
February 1, 2016
Thanks. Can you point me at docs for how Tab Sequence works?
