Delete Application Logs with a script
  • August 23, 2016
  • 3 replies
  • 3448 views
Is there a way to delete application logs entries with a script from ThingWorx ? I saw in the LogView mashup that we have access to the ApplicationLog resource that has a QueryLogEntries function, but i couldn't find any function similar to deleteStreamEntry or purgeStreamEntries anywhere.
Any advice on this ?
Thank you,
Veronica
Best answer by Aanjan
Veronica, the Logging Subsystem has settings where you can configure the retention for logs (default is 100mb and 7 days). The logs are usually dynamically generated, so we don't recommend running the purge to clear out existing entries though a custom service.
Aanjan5-Regular MemberAnswer
Why do you want to do this? I don't believe there is any built-in functionality for this in ThingWorx, but you could always just delete or rename the ApplicationLog.log file found within the /ThingWorxStorage/logs folder.
Hope this helps!
Tori
vmihai1-VisitorAuthor
Thank you for your answers. I want to prevent the space on the hard drive from increasing  because of the logs. I will look into the Logging Subsystem and set it up from there.
