Detect mobile device
  • November 8, 2016
  • 2 replies
  • 2321 views
Is there any way to detect from TW global js, if the mashup is loaded from mobile device? I would like adjust widgets I made to fit on mobile based on this option, probably can be done by measuring viewport in jQuery, but is there any internal variable I can access?
Regards Jan.
Best answer by BrunoD
Hello Jan,
In order to set the viewport parameter for rendering mashups on mobile displays, you need to use an extension.
Please follow this link to find an exemple of extension adding viewport parameter:
MobileHeader Extension
Bruno
BrunoD12-AmethystAnswer
Hello Jan,
Bruno
jgabriel1-VisitorAuthor
Yes I did almost the same extension: GitHub - Foxoncz/tw-metawidget-ext
