Does thingworx work on CentOs..?
  • January 15, 2018
  • 5 replies
  • 2732 views
I would like to know whether thingworx works on centOs or not..?
We are not having RHEL??
madhu
Best answer by dupatel
Madhu Nalla​: You can use it for local instance and should work fine without issue. Since, it is not tested/listed officially and only those OS mentioned in compatibility matrix are the recommended/supportable ones in Production/Dev instances.
-Durgesh
I dont see the official support for CentOS 7.x- however it works fine on my side.
Martin
Madhu Nalla​: Please refer to the support compatibility matrix   for recommended OS details. This is specific to ThingWorx version so will have to consider that during evaluation. Do you have access to the PTC eSupport portal? Can you access this reference documents section? The pdf is available there too.
-Durgesh
mnalla1-VisitorAuthor
Dear Durgesh,
This is fine. but I want to use CentOs, Does it support??
madhu
dupatel5-Regular MemberAnswer
-Durgesh
