Dynamic columns from Infotable
  • July 18, 2017
  • 11 replies
  • 8227 views
I'm getting different Infotables with different count of columns. Say, table1 with 10 columns and table with 20 columns and these columns(names) are not fixed,may change frequently.
Now I want to show all the columns from all the infotable onto a single GRID.
In short,I don't have any predefined DataShape to bind.
How to achieve that?
I have tried below approach:
// result: INFOTABLE dataShape: RootEntityList  //Fetching Thing Names on the basis of ThingShape Name
var thingNames = ThingShapes[ThingShapeName].GetImplementingThings();
//Creating Dynamic Infotable with no Datashape
var params = {
infoTableName: "MyTable" /* STRING */
//result: INFOTABLE
var result = Resources["InfoTableFunctions"].CreateInfoTable(params);
//Looping to get thingName and get its Properties and adding its row in Dynamic Infotable,created above
var tableLength = thingNames.rows.length;
for (var y = 0; y < tableLength; y++)
var Tname = thingNames.rows.name;
var propertyValue = Things[Tname].GetPropertyValues();
   result.AddRow(propertyValue.rows[0]);
Output: Infotable without DataShape
Mashup Bind: Grid bind to ALL DATA with "Show All Columns" option to "true".
Best answer by CarlesColl
Hi Tarun,
Just add a ""+ in front of iLF[key ].baseType :
var iLF ;//
if ((data.dataShape==null)||(data.dataShape==undefined)) {
   iLF = data.ToJSON().dataShape.fieldDefinitions;
} else {
   iLF = data.dataShape.fields;
for (var key in iLF) {
   result.AddField({ name: key, baseType: (""+iLF[key].baseType) });
Tarun Nayyar​,
Did it work with your approach? Did you have any error during running your code(please attach it if any)? Or it worked for you and you are still looking for
any better approach from the community?
Br,
Anna
Hi Anna,
I think he was doing a code sample, not asking.
Carles.
TanmeyTWX17-PeridotAuthor
Hi Ann/Carles,
My approach didn't work for me. It neither throw any error nor any data display onto grid. I'm getting Grid with blank rows as below.
You must use AddField snippet on the result previous adding data.
Carles,
Sorry, didn't get you.
