EMS Tunneling is disconnected
  • November 22, 2016
  • 1890 views
I installed EMS, and it successfully connected to the Platform.
However, when I create an SSH tunnel to the EMS with Remote Access Widget,
connection fails with following messages.
1. When I click on the Remote Access Widget, WSEMS log shows
TUNNEL NOTIFICATION:
ThingName: TestThing
State: STARTED
Target: 127.0.0.1:22
StartTime: 2016-11-22 09:15:31,976
EndTime: Still in Progress
Duration: 0 msec
User: Unknown
Bytes Sent: 0
Bytes Rcvd: 0
Message:
2. But after some seconds or minutes,
State: ENDED
StartTime: 2016-11-22 09:14:36,793
EndTime: 2016-11-22 09:16:07,464
Duration: 90671 msec
User: Administrator
Bytes Sent: 41
Bytes Rcvd: 0
Message: An unrecoverable IOException occurred so the connection was closed
When I attempt to connect via localhost:16345 with TeraTerm, username/password prompt appears.
But I can never complete login because End of Tunnel occurs before/at the same time as pressing OK button on the TeraTerm's login prompt.
Does anyone have idea?
Edge
  Raspberry Pi 3
  WSEMS Version5.3.1 (Linux-ARM-HWFPU)
Platform
  ThingWorx 7.0.1
Network
  Wifi Router (no proxy, can establish SSH connection via 22 port directly)
Shunsuke Yamabe
Best answer by ???-31
Now we have just solved this problem by ourselves.
We should check "AcceptSelfSignedCert" as we use self signed certification.
As I checked this configuration, I could successfully establish the SSH session.
???-311-VisitorAuthorAnswer
