Error importing Things_SteamSensor1.xml for the Android SDK excercise
  • September 21, 2016
  • 4 replies
  • 2507 views
I'm trying to import the Things_SteamSensor1.xml entity into my local Thingworx instance (v7.2.0) and the next error shows:
Anyone with the same error? Or any idea of where to find that DataShape?
Thanks on advance.
Best answer by ankigupta
Hi Josue Serrano​,
Please refer to PTC KCS article CS233150 and see if it helps. It seems related.
Ankit Gupta
ankigupta5-Regular MemberAnswer
Hi Josue Serrano​,
Ankit Gupta
jserrano1-VisitorAuthor
This is exactly what I needed. I did create the Remote Thing and its properties, but this is the complete and full solution. Thank you Ankit.
Josue Serrano​ , Besides following the resolution mentioned in KCS Article like:
  • Setup the Steam Sensor example in Eclipse first and run the example
  • Create a Steam Sensor Remote Thing in Composer and Bind it to the remote Thing
  • Add the remote service from the Java SDK and the DataShape will be included properly
  • The ExampleExport.xml file is not meant to be imported on its own Workaround
  • Create a DataShape with the name SteamSensorReadingsPlus and import the entities
You can also create a RemoteThing in Thingworx server and bind it virtual object in the SDK .
Please follow the steps send by me and let me know if you are able to establish connection and understand the complete mechanism.
Ravi Upadhyay.
Thank you Ravi. It was really helpful.
