Error Reading Json Element in Array with Dash "-" in Name
  • May 30, 2017
  • 3 replies
  • 2441 views
I'm trying to create an infotable from a JSON array that is in a logged property.  The problem is that one of the elements in the array has a dash in the name ("arc-time").  I cannot change the element but can't get it to come through.  The following code gives me an error: "missing name after .operator".  Any ideas?
var obj= me.ErrorHistory;
var params = {
    infoTableName: "InfoTable",
    dataShapeName : "ErrorHistory_Shape"
var infotabletest = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
for(var i=0; i<obj.array.length; i++)
    infotabletest.AddRow({"id":obj.array.id,"type":obj.array.class,"arctime":obj.array.["arc-time"]});
var result= infotabletest;
Best answer by CarlesColl
When you get a field value with ["arc-time"] no "." should be written, then your instruction should be:
infotabletest.AddRow({"id":obj.array.id,"type":obj.array.class,"arctime":obj.array["arc-time"]});
20-Turquoise
May 31, 2017
What is your Thingworx platform version?
I will recreate, and if a bug is confirmed, submit a jira.
rflanagan1-VisitorAuthor
That worked Carles!.  I knew it was something small. Thanks!
