error with command "npm run setup-examples" in step 7 of 12,ThingWorx RPI Quickstart
  • September 8, 2016
  • 1464 views
npm-debug.log is pasted below.
0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node',
1 verbose cli   '/usr/local/bin/npm',
1 verbose cli   'run',
1 verbose cli   'setup-examples' ]
2 info using npm@2.11.2
3 info using node@v0.12.6
4 verbose run-script [ 'presetup-examples', 'setup-examples', 'postsetup-examples' ]
5 info presetup-examples thingworx-agent-examples@0.0.1
6 verbose unsafe-perm in lifecycle true
7 info setup-examples thingworx-agent-examples@0.0.1
8 verbose unsafe-perm in lifecycle true
9 info thingworx-agent-examples@0.0.1 Failed to exec setup-examples script
10 verbose stack Error: thingworx-agent-examples@0.0.1 setup-examples: `node setup-examples.js`
10 verbose stack Exit status 1
10 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:213:16)
10 verbose stack     at EventEmitter.emit (events.js:110:17)
10 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
10 verbose stack     at ChildProcess.emit (events.js:110:17)
10 verbose stack     at maybeClose (child_process.js:1015:16)
10 verbose stack     at Process.ChildProcess._handle.onexit (child_process.js:1087:5)
11 verbose pkgid thingworx-agent-examples@0.0.1
12 verbose cwd /home/pi/thingworx-nodejs-agent/thingworx-agent-examples
13 error Linux 4.4.11+
14 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "setup-examples"
15 error node v0.12.6
16 error npm  v2.11.2
17 error code ELIFECYCLE
18 error thingworx-agent-examples@0.0.1 setup-examples: `node setup-examples.js`
18 error Exit status 1
19 error Failed at the thingworx-agent-examples@0.0.1 setup-examples script 'node setup-examples.js'.
19 error This is most likely a problem with the thingworx-agent-examples package,
19 error not with npm itself.
19 error Tell the author that this fails on your system:
19 error     node setup-examples.js
19 error You can get their info via:
19 error     npm owner ls thingworx-agent-examples
19 error There is likely additional logging output above.
20 verbose exit [ 1, true ]
@xiong liu .
$ npm run setup-examples is  executed to install all the dependency packages. Here the example script is 'node-setup-examples.js is failing.
I would suggest deleting  the thingworx-nodejs-agent folder and its contents and try to download the thingworx-nodejs-agent afresh from .
Since , You are just starting, this suggestion is advisable and it will save lot of time.
