Expression Changed event
  • November 20, 2017
  • 7 replies
  • 4646 views
Hi. I'm trying to open a popup mashup only if a parameter that I pass to a expression widget have certian value. So, i added the widget to the mashup and binded the changed event to the "navigate" service on my navigation widget but it doesn't work, i also selected on the DataChangeType dropdown  the "value" option, with no success. Thank You for your time. I attached a picture with the configuration of the expression widget.
Best answer by AdamR
Hi Eddison,
It sound like for what you are trying to accomplish a Validator widget may be better.  This allows a true/false check and will trigger every time the expressions returns true.
Adam
Few things: - Output it's an input parameter of the expression widget? - Output=true --> You are assigning true to Output, I think your code should be Output==true ( comparision ) - You have "FireOnFirstValue"=false, that means it won't trigger data change the first time it's evaluated - I see that you have evaluate binded, then it seems this part it's ok, otherwise you will have to set AutoEvaluate=true Best Regards, Carles.
Hi Carles, thanks for the response.
Yes, I know i'm assigning the value "true" to Output just to force the change, if i check the FireOnFirstValue it trigger the change but only once, after that it won't trigger again, i checked the AutoEvaluate but it doesn't trigger anyway.
It should works, there should be other wrong things, but the value changes or you are just evaluating it with the same value? if that the case you can change it the DAtaChangeType to Always.
AdamR14-AlexandriteAnswer
Hi Eddison,
Adam
Hi, Adam. Thank Your for the reply.. I'll try that tomorrow and tell you if it worked.
