Fire an event from a service
  • July 12, 2016
  • 4 replies
  • 3294 views
Hi!
How can i fire the event from inside the service code?
As an example: if validation fails inside the service i would like to fire an ValidationFails event.
Is this possible?
Best answer by CarlesColl
About the Log, if you want to record debug type logs, you should activate Debug Log level:
Composer > Monitoring > Script
On the Log View Mashup
Logs > Settings  ( tab )
Inside settings tab:
Script Log --> New Settings = Debug
me.name_of_the_event(params);
rmórocz1-VisitorAuthor
Hi Carles!
I have this in my code
(Test is an event)
Code of my test service:
var params = {
  Message: "Hello" /* STRING */,
me.Test(params);
And i have a subscription to this event (enabled). In the subscription i have this:
logger.debug(eventData.Message);
But "Hello" is still not showing in the script log.
What is missing?
