Font Labeling extension gives import error
  • July 9, 2015
  • 3 replies
  • 2176 views
I have downloaded Font Labeling extension from Thingworx Marketplace. While importing I am getting below error.
Error importing: error: Not Acceptable - [package: FontLabel_Test_kit, error: \ThingworxStorage\extensions\FontLabel_Test_kit_0b5a4901-e17f-46ce-8690-09a601727ba6\FontLabel_Test_kit\metadata.xml (The system cannot find the file specified)]
Thingworx Version:  Thingworx 6.0.0 b452
Java: 1.8.0_45 !
    Best answer by stefanp
    Hi Ketan,
    What you have downloaded form the market place is a zip file which is not the extension itself. The extension is inside that archive along with some other files. The extension zip file is called FontLabel.zip.  Please read the README.txt for installing which goes:
    # FontLabel widget   #
    1. Install the widget.
    2. Upload one of the entity files (depending on TW version 5.x or 6.0) and find the test mashup that was just imported (6.0 - FontLabel; 5.x - TestFontLabelMashup). There are 3 fonts already uploaded in MediaEntities : Code39, Code128, LiveWired.
    3. Enjoy! (Download and upload your own ttf fonts)
    Stefan
    stefanp5-Regular MemberAnswer
    Hi Ketan,
    Stefan
    kmagdum14-AlexandriteAuthor
    Thanks Stefan! I am able to use this widget now.
