Get the selected row from a contained mashup
  • March 29, 2017
  • 15 replies
  • 8644 views
I have a mashup where I launch a service in order to get an infotable which contains data for a Tree Table I want to display.
The Tree Table will be displayed in a contained mashup (name coming from another service) as depending on some parameters I don't want to show the same columns and rendering. I have added to the contained mashups a "Tree" parameters which is my infotable binded to the result of my service.
My problem is that when a row is selected in the Tree Table, I don't know how to provide the selected row to the parent mashup. I need that selected row for other purposes.
Thanks in advance for your help.
Best answer by nlaffargue
Hi Carles!
I think I found another solution by passing the primary key to the parent mashup and using an invisible dropdown list to select the row in the data.
Then I can use the selectedRow from the parent data directly.
https://www.dropbox.com/s/e0lzwp9pc3ugsrq/NicolasLaffargueSampleInnerSelectedRowV3.xml?dl=0
Best regards,
Dear Nicolas,
Regarding how to get the selectedRows from contained mashup, here is some steps you could follow and it should work:
1. in your contained mashup, create a Tree widget, and bind the necessary service to it, e.g., call GetDataTableEntries from a DataTable you created
2. in UserManagementSubsystem User Session Shape Settings section, add a new ThingShape "ts1" with only one property "selectedRows" with INFOTABLE type
3.bind the Selected Row(s) to the session's "selectedRows" parameter:
4. Likely, in your parent mashup, bind the selectedRows in session to the widget(e.g., you want to display the selectedRows in a Grid) :
5. view the mashup, you should see the Grid data change accordingly when the Tree table selected rows changed in the contained mashup.
Hope this helps,
Br,
Anna
I think you can do it without using Session Variables, you just add a parameter on the inner mashup with the values you want to return as selected row, and then you just need to bind selected rows values to Mashup Parameters, this will be cleaner than Session Variables and also you don't mess up Session Variables for just a Mashup.
Hi Carles,
Thanks for your suggestion. It is working when I want to return specific attributes to the parent mashup but in my case I would like to provide the full selected row as an infotable because it contains lots of attributes and I would like to avoid creating twenty mashup parameters.
I don't know exactly why (looks like a "bug") but I can display in the parent mashup the selected row in a grid but I can't bind specific attributes to widgets (no arrow available as you can see in the screenshot)
The only workaround I see should be to have a useless service which gets and returns the same infotable and call this service when a selected row is changed in the contained mashup... This way I will be able to bind attributes to my widgets.
