Has anyone been able to successfully configure Thingworx 7.4 to use MS SQL Server?
- May 15, 2017
- 3 replies
- 3082 views
I'm keen to connect Thingworx to SQL Server as the persistence provided now that it is an option with 7.4. However I am struggling to make the database connection. My ApplicationLog.log persists in showing message: Unable to initialize and start system: Connections could not be acquired from the underlying database! despite everything I've tried.
I've confirmed that my user/password is the same I used to create the SQL Server db using the PTC provided scripts. I confirmed this by logging in to the db via SQL Developer and a JDBC driver.
I've attached my ApplicationLog.log file along with my platform-settings.json file (user/password is twadmin/wcadmin for dev environment sake)
If anyone has successfully connected could you share your platform-settings.json along with any tips you might have uncovered?
Thank you!
Greg
